configure ospfv3 interface area
configure ospfv3 [vlan vlan_name | tunnel tunnel_name] area area_identifier
Description
Moves an interface from one OSPFv3 area to another.
Syntax Description
vlan_name Specifies an IPv6 configured VLAN.
tunnel_name Specifies an IPv6 tunnel.
area_identifier Specifies an OSPFv3 area, a four-byte, dotted decimal number.
Default
N/A.
Usage Guidelines
Use this command to move an already configured interface from one area to another. The instance ID associated with the interface will be unchanged.
The following command moves the VLAN accounting to the OSPFv3 area 0.0.0.6:
configure ospfv3 vlan accounting area 0.0.0.6
Platform Availability
This command is available on all platforms with a Base license or higher as described in the licensing guide.
