enable rip
enable rip
Description
Enables RIP for the whole router.
Syntax Description
Default
Disabled.
Usage Guidelines
RIP has a number of limitations that can cause problems in large networks, including:
  • A limit of 15 hops between the source and destination networks.
  • A large amount of bandwidth taken up by periodic broadcasts of the entire routing table.
  • Slow convergence.
  • Routing decisions based on hop count; no concept of link costs or delay.
  • Flat networks; no concept of areas or boundaries.
The following command enables RIP for the whole router:
# enable rip
Platform Availability
This command is available on all platforms with an Edge, Advanced Edge, or Core license.
