enable log target upm
enable log target upm {upm_profile_name}
Description
Enables the specified UPM log target.
Syntax Description
upm_profile_name Specifies the name of the UPM log target to be enabled.
Default
N/A.
Usage Guidelines
UPM log targets are disabled when they are created.
The following command enables the UPM log target testprofile1:
enable log target upm testprofile1
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the Universal Port feature, see the Switch Engine v33.6.1 Licensing Guide document.
