show ospf interfaces
show ospf interfaces {vlan vlan-name | area area-identifier | enabled}
Description
Displays information about one or all OSPF interfaces.
Syntax Description
vlan-name Specifies a VLAN name.
area-identifier Specifies an OSPF area.
enabled Displays only OSPF enabled interfaces.
Default
If no argument is specified, all OSPF interfaces are displayed.
Usage Guidelines
Not applicable.
The following command displays information about one or all OSPF interfaces on the VLAN accounting:
show ospf interfaces vlan accounting
The following output displays BFD protection configuration information:
# show ospf interfaces
VLAN      IP Address         AREA ID        Flags      Cost State   Neighbors
HQ_10_0_2  10.0.2.2       /24 0.0.0.0         -rifb--      4/A R        1
HQ_10_0_5  10.0.5.2       /24 0.0.0.0         -rif---      4/A BR       1
Flags:  b – BFD protection configured, f - Interface Forwarding Enabled,
        i - Interface OSPF Enabled, n - Multinetted VLAN,
        p - Passive Interface, r - Router OSPF Enable,
Cost:   A - Automatic Cost, C - Configured Cost.
Total number of interfaces: 2
The following output displays the BFD session state:
Interface(rif1000027): 10.0.2.2/24 Vlan: HQ_10_0_2 OSPF: ENABLED Router: ENABLED
AreaId: 0.0.0.0  RtId: 10.0.2.2  Link Type: broadcast(auto)  Passive: No
Cost: 4/A  Priority: 10 Transit Delay: 1   DAD State:Valid
Hello Interval: 10s  Rtr Dead Time: 40s Retransmit Interval: 5s
Wait Timer: 40s
Authentication: NONE
State: DR   Number of events: 1
DR RtId: 10.0.2.2  DR IP addr: 10.0.2.2 BDR IP addr: 10.0.2.1
Num Neighbor State Change to FULL : 1
BFD Protection: On
Neighbors:
    RtrId: 10.0.3.1 IpAddr: 10.0.2.1  Pri: 5  Type: Auto
    State: FULL Dr: 10.0.2.2  BDR: 10.0.2.1  Dead Time: 00:00:00:03
    Options (0x42): Opaque LSA: Yes
    BFD Session State: Active
The enabled option was added in ExtremeXOS 12.2.
BFD display output was added in 15.3.2.
The D (duplicate address detected on VLAN) and T (tentative address) flags were removed in ExtremeXOS 30.1.
Platform Availability
This command is available on all platforms with a Base license or higher as described in the licensing guide.
