disable igmp
disable igmp {vlan name}
Description
Disables IGMP on a router interface. If no VLAN is specified, IGMP is disabled on all router interfaces.
Syntax Description
name Specifies a VLAN name.
Default
Enabled.
Usage Guidelines
IGMP is a protocol used by an IP host to register its IP multicast group membership with a router. Periodically, the router queries the multicast group to see if the group is still in use. If the group is still active, hosts respond to the query, and group registration is maintained.
IGMP is enabled by default on the switch. However, the switch can be configured to disable the generation and processing of IGMP packets. IGMP should be enabled when the switch is configured to perform IP multicast routing.
This command disables IGMPv2 and IGMPv3.
The following example disables IGMP on VLAN accounting:
disable igmp vlan accounting
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the IPv4 multicast feature, see the Switch Engine v33.6.1 Licensing Guide document.
