configure ospf routerid
configure ospf routerid [automatic | router-identifier]
Description
Configures the OSPF router ID. If automatic is specified, the switch uses the highest IP interface address as the OSPF router ID.
Syntax Description
automatic Specifies to use automatic addressing.
router-identifier Specifies a router address.
Default
Automatic.
Usage Guidelines
Each switch that is configured to run OSPF must have a unique router ID. It is recommended that you manually set the router ID of the switches participating in OSPF, instead of having the switch automatically choose its router ID based on the highest interface IP address. Not performing this configuration in larger, dynamic environments could result in an older link-state database remaining in use.
Do not set the router ID to 0.0.0.0.
The following command sets the router ID:
configure ospf routerid 10.1.6.1
Platform Availability
This command is available on all platforms with a Base license or higher as described in the licensing guide.
