clear netlogin state
clear netlogin state {port port_list}
Description
Clears and initializes the network login sessions on a VLAN port.
Syntax Description
port_list Specifies the ports to clear.
Default
None.
Usage Guidelines
Clear the states of every MAC learned on this VLAN port and put the port back to unauthenticated state. The port will be moved to its original VLAN if configured in campus mode.
The following command clears the Network Login state of port 2:9:
clear netlogin state port 2:9
The following is an example message when this command is run for a port that does not have NetLogin enabled:
# clear netlogin state port 1:1
Note: The following ports do not have NetLogin enabled: 1:1
This command was first available in ExtremeXOS 11.1.
Platform Availability
