show mld snooping
show mld snooping {vlan name | detail} {MLDv2}
MLD snooping is not supported in this software release.
Description
Displays MLD snooping registration information and a summary of all MLD timers and states.
Syntax Description
name Specifies a VLAN name.
detail Displays the information in detailed format.
MLDv2 Displays the MLD group in MLDv2 format (if group record is MLDv2 compatible, otherwise displays in earlier format). This option is not supported in this release.
Default
MLDv1.
Usage Guidelines
The two types of MLD snooping entries are sender entry and subscribed entry.
The following information is displayed in a per-interface format:
  • Group membership information
  • Router entry
  • Timeout information
  • Sender entry
Here is an example of the show output:
# show mld snooping
MLD Snooping Flood-list : none
MLD Snooping Proxy      : Enable
MLD Snooping Filters    : per-port
Vlan             Vid  Port   #Senders #Receivers Router Enable
Default          1           0                           Yes
v1               4084        0                           Yes
25               1          Yes
41               2          No
42               2          No
The following command displays MLD snooping registration information for the VLAN V1:
# show mld snooping v1
Router Timeout                :    260 sec
Host Timeout                  :    260 sec
MLD Snooping Fast Leave Time  :   1000 ms
VLAN v1               (4084) Snooping=Enabled
Port    Host                                           Age
Subscribed                                    Join Limit
25    fe80::204:96ff:fe3a:ce50                        13
ff02::1:ff3a:ce50                               No Limit
25    fe80::204:96ff:fe3a:ce50                        14
All Groups                                      No Limit
41    fe80::200:8ff:fe55:5c27                         13
ff02::1:ff00:2                                  No Limit
ff02::1:ff55:5c27                               No Limit
42    fe80::200:8ff:fe56:5c2b                         14
42    fe80::200:8ff:fe56:5c2b                         13
ff02::1:ff56:5c2b                               No Limit
s = static MLD member
Platform Availability
This command is available on the platforms listed for the IPv6 multicast routing feature in the Switch Engine v33.6.1 Licensing Guide document.
