show mpls
show mpls
Description
Displays MPLS configuration information.
Syntax Description
Default
N/A.
Usage Guidelines
The show mpls command displays the current values for all the MPLS configuration parameters that apply to the entire switch. The parameters displayed include:
  • MPLS and MPLS protocol (RSVP-TE and LDP) status.
  • SNMP traps configuration.
  • EXP examination/replacement configuration.
  • the MPLS LSR ID.
  • the list of the VLANs which have been added to MPLS.
The following command displays the MPLS configuration parameters for the switch:
# show mpls
MPLS System
MPLS System            : User VR (Green)
MPLS Admin Status      : Enabled
MPLS Oper Status       : Enabled
RSVP-TE Admin Status   : Enabled
RSVP-TE Oper Status    : Enabled
LDP Admin Status       : Enabled
LDP Oper Status        : Enabled
SNMP Traps             : Disabled
L2VPN SNMP Traps       : Enabled
EXP Examination        : Disabled
EXP Replacement        : Disabled
LSR ID                 : 11.100.100.20
This command was first available in ExtremeXOS 11.6
Platform Availability
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.6.1 Licensing Guide document.
