This command clears all IS-IS-related counters in the current virtual router.
N/A.
This command clears all area and VLAN counters.
The following area counters are cleared: corrupted LSPs, LSPDB overloads, manual address from area count, LSP sequence number wraps, LSP sequence number skips, LSP purges, partition changes, and SPF calculations.
The following VLAN counters are cleared: adjacency changes, adjacency initialization failures, rejected adjacencies, ID field length mismatches, maximum area address mismatches, authentication type failures, authentication failures, DIS changes, hello PDU TX and RX count, LSP TX and RX count, CSNP TX and RX count, PSNP TX and RX count, unknown PDU type TX and RX count.
The following command clears all IS-IS counters:
clear isis counters
This command is available on all platforms with a Premier or Extreme Platform ONE license as described in the licensing guide.
