enable mpls
enable mpls
Description
Enables MPLS on the switch.
Syntax Description
Default
Disabled.
Usage Guidelines
Enabling MPLS allows MPLS processing to begin for any enabled MPLS protocols (RSVP-TE and/or LDP).
While MPLS is transitioning to the enabled state, only the MPLS show commands are accepted.
Before you can enable MPLS on a SummitStack, the stack must meet the following requirements:
  • Each stack switch must meet the software and hardware requirements listed in the Switch Engine v33.6.1 Licensing Guide document.
  • You must configure the enhanced stacking protocol on each ExtremeSwitching series switch.
    When MPLS is enabled on a stack, you can only add MPLS-compatible switches to the stack.
The following command globally enables MPLS on the switch:
enable mpls
This command was first available in ExtremeXOS 11.6.
Platform Availability
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.6.1 Licensing Guide document.
