enable ospf export
enable ospf export [bgp | direct | direct-inter-vr | e-bgp | i-bgp | rip | static | isis | isis-level-1 | isis-level-1-external | isis-level-2 | isis-level-2-external | host-mobility] [cost cost type [ase-type-1 | ase-type-2] {tag number} | policy-map]
Description
Enables redistribution of routes to OSPF.
Syntax Description
bgp Specifies BGP routes.
direct Specifies direct routes.
direct-inter-vrSpecifies Inter-VR leaked direct routes.
e-bgp Specifies E-BGP routes.
i-bgp Specifies I-BGP routes.
rip Specifies RIP routes.
static Specifies static routes.
isis Specifies IS-IS routes.
isis-level-1 Specifies ISIS Level 1 routes.
isis-level-1-external Specifies ISIS Level 1 External routes.
isis-level-2 Specifies ISIS Level 2 routes.
isis-level-2-external Specifies ISIS Level 2 External routes.
host-mobilitySpecifies host-mobility routes.
cost Specifies a cost metric.
ase-type-1 Specifies AS-external type 1 routes.
ase-type-2 Specifies AS-external type 2 routes.
number Specifies a tag value.
policy-map Specifies a policy.
Default
The default tag number is 0. The default setting is disabled.
Usage Guidelines
After OSPF export is enabled, the OSPF router is considered to be an ASBR. Interface routes that correspond to the interface that has OSPF enabled are ignored.
The cost metric is inserted for all BGP, IS-IS, RIP-learned, static, and direct routes injected into OSPF. If the cost metric is set to 0, the cost is inserted from the route. The tag value is used only by special routing applications. Use 0 if you do not have specific requirements for using a tag. The tag value in this instance has no relationship with 802.1Q VLAN tagging.
The same cost, type, and tag values can be inserted for all the export routes, or a policy can be used for selective insertion. When a policy is associated with the export command, the policy is applied on every exported route. The exported routes can also be filtered using a policy.
The following command enables OSPF to export BGP-related routes using LSAs to other OSPF routers:
enable ospf export bgp cost 1 ase-type-1 tag 0
The following example shows all route types that can be configured with this command:
# enable ospf export
  <route_type>    OSPF export route type
    "bgp"                    "direct"                “direct-inter-vr”
    "e-bgp"                  "host-mobility"         "i-bgp"
    "isis"                   "isis-level-1"          "isis-level-1-external"
    "isis-level-2"           "isis-level-2-external" "rip"
    "static"
Platform Availability
This command is available on all platforms with a Base license or higher as described in the licensing guide.
