enable license trial
Description
Enables a trial software license that allows you to use advanced features.
Syntax Description
trial
Specifies to enable the trial license.
Default
N/A.
Usage Guidelines
When you enable a trial license, the system generates a daily message showing the number of days until expiry.
The following command enables a trial license on the specified switch:
This command was first available in version 33.2.1.
Platform Availability
