Resets the EXP value assigned to the QoS profile back to the default EXP value.
| qosprofile | Specifies the QoS profile whose EXP replacement value is unconfigured. |
The EXP value matches the QoS profile -1.
This command resets the EXP value assigned to the QoS defined by qosprofile back to the default EXP value. If the all option is specified, all QoS profiles are reset back to their default EXP values. By default, the EXP value matches the QoS profile - 1. That is, QoS profile qp1 is mapped to EXP value of 0, QoS profile qp2 is mapped to EXP value of 1, etc. This configuration has switch-wide significance.
Use the following command to restore all EXP values to their default setting:
unconfigure mpls exp replacement all
This command was first available in ExtremeXOS 11.6.
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.6.1 Licensing Guide document.
