configure pim spt-threshold
configure pim {ipv4 | ipv6} spt_threshold [infinity | leaf_threshold] {rp_threshold}
Description
Configures the threshold, in kbps, for switching to SPT. On leaf routers, this setting is based on data packets. On the RP, this setting is based on register packets. When infinity option is configured on First Hop Routers or Intermediary Routers, SPT switching is disabled. Traffic forwarding will be performed based on RPT paths only.
Syntax Description
ipv4 Specifies the IPv4 address family.
ipv6 Specifies the IPv6 address family.
infinity Disables Shortest Path Tree (SPT) switching on Last Hop or Intermediary routers.
leaf-threshold Specifies the rate of traffic per (s,g,v) group in kbps for the last hop. Range is 0 - 4194303.
rp_threshold Specifies an RP threshold. Range is 0 - 4194303.
Default
The default setting is 0 for both parameters.
Usage Guidelines
For the best performance, use default value of 0.
The following example changes the threshold for switching to SPT:
configure pim spt-threshold 4 16
The infinity option was added in ExtremeXOS 15.7.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the PIM feature, see the Switch Engine v33.6.1 Licensing Guide document.
