show bgp neighbor
For IPv4 and IPv6 address families:
show bgp {neighbor} remoteaddr {address-family [ipv4-unicast | ipv4-multicast |ipv6-unicast | ipv6-multicast | ipv4-vxlan | {l2vpn-evpn [inclusive-multicast | mac-ip | auto-discovery | esi | ip-prefix]}]} [accepted-routes | received-routes | rejected-routes | transmitted-routes] {detail} [all | as-path path-expression | community [no-advertise | no-export | no-export-subconfed | number community_number | autonomous-system-id : bgp-community] | network [any/netMaskLen | networkPrefixFilter] {exact}]
For the VPNv4 address family:
show bgp {neighbor} remoteaddr address-family vpnv4 [accepted-routes | received-routes | rejected-routes | transmitted-routes] {detail} [all | as-path path-expression | community [no-advertise | no-export | no-export-subconfed | number community_number | autonomous-system-id :bgp-community] | rd rd_value network [any/netMaskLen | networkPrefixFilter] {exact}]
Description
Displays information about routes to a specified neighbor.
Syntax Description
remoteaddr Specifies an IPv4 or IPv6 address that identifies a BGP neighbor.
ipv4-unicast Specifies IPv4 unicast routes.
ipv4-multicast Specifies IPv4 multicast routes.
ipv6-unicast Specifies IPv6 unicast routes.
ipv6-multicast Specifies IPv6 multicast routes.
ipv4-vxlan Specifies IPv4 VXLAN routes.
l2vpn-evpn Specifies an L2VPN EVPN address family.
inclusive-multicast Displays EVPN inclusive-multicast (type 3) routes
mac-ip Displays EVPN MAC/IP (type 2) routes.
auto-discovery Displays EVPN auto-discovery (type 1) routes.
esi Displays EVPN Ethernet segment (type 4) routes.
ip-prefix Displays EVPN ip-prefix (type 5) routes.
vpnv4 Specifies VPNv4 routes.
accepted-routes Specifies that only accepted routes are displayed.
received-routes Specifies that only received routes are displayed.
rejected-routes Specifies that only rejected routes are displayed.
transmitted-routes Specifies that only transmitted routes are displayed.
detail Specifies to display the information in detailed format.
all Specifies all routes.
path-expression Display routes that match the specified AA path expression.
no-advertise Specifies the no-advertise community attribute.
no-export Specifies the no-export community attribute.
no-export-subconfed Specifies the no-export-subconfed community attribute.
community_number Specifies a community number.
autonomous-system-id Specifies an autonomous system ID (0-65535).
bgp-community Specifies the BGP community number.
rd Specifies the Route Distinquisher (RD) value for the Layer 3 VPN routes for which you want to clear flap statistics.
any Specifies all routes with a given or larger mask length.
netMaskLen Specifies a IPv4 or IPv6 subnet mask length (number of bits).
networkPrefixFilter Specifies an IPv4 or IPv6 address and netmask.
exact Specifies an exact match with the IP address and subnet mask.
Default
If no address family is specified, IPv4 unicast is the default.
Usage Guidelines
show bgp neighbor now supports v6 unicast and multicast and vpnv4 address families. This command applies to the current VR or VRF context.
If this command displays Bad Source Address, the BGP neighbor IP address is unavailable. Possible causes for this condition include a deleted or unconfigured VLAN or IP address.
The option network any / netMaskLen displays all BGP routes whose mask length is equal to or greater than maskLength, irrespective of their network address.
The option network any / netMaskLen exact displays all BGP routes whose mask length is exactly equal to maskLength, irrespective of their network address.
If you do not specify an address family, this command applies to the IPv4 unicast address family. To apply this command to an address family other than the IPv4 unicast address family, you must specify the address family.
For an IPv6 peer, an IPv6 address family must be specified, because an IPv6 peer does not support IPv4 address families. If no address family is specified for an IPv6 peer, the default address-family, i.e. IPv4 unicast is assumed and hence no address-family information appears. Similarly an IPv4 peer only supports IPv4 address families and no address-family information appears if an IPv6 address family is specified.
To display Layer 3 VPN information, you must enter this command in the context of on the MPLS-enabled VR; it is not supported for BGP neighbors on the CE (VRF) side of the PE router.
The following command displays sample output when an error message is generated when the user attempts to create more than the limit of 2 peering sessions with a Base license on VR-Default (including any child VRFs of VR-Default:
# show bgp neighbor
     Peer                                    AS         Weight State        InMsgs OutMsgs(InQ)  Up/Down
Id-- 10.1.1.1                                10         1      IDLE         0      0     (0    ) 0:0:13:53
Id-- 20.1.1.1                                10         1      IDLE         0      0     (0    ) 0:0:00:07
Flags: (d) disabled, (e) enabled, (E) external peer, (I) internal peer
switch-model-EXOS.24 # create bgp neighbor 30.1.1.1 remote-AS-number 10
Error: Core license is required to configure more than 2 peers
Base License (User VR):
* (vr user1) switch-model-EXOS.29 # create bgp neighbor 30.1.1.1 remote-AS-number 50
Error: vr user1: Core license is required to configure peer on VR other than VR-Default
The following command displays sample output for show bgp neighbor summary:
# show bgp neighbor
Ie-- 11.0.0.2       100   0           OPENSENT     0      9      (0    ) 0:8:27:21
Ie-- 3001::1        100   0           ESTABLISEHD  4      3      (0    ) 0:8:27:21
        (m) EBGP multihop, (r) route reflector client
BGP Peer Statistics
Total Peers      : 2
EBGP Peers       : 0
IBGP Peers       : 2
RR Client        : 0
EBGP Multihop    : 0
Enabled          : 2
Disabled         : 0
The following example displays show output for an IPv4 peer:
# show bgp neighbor 192.168.66.2
Peer Description    :
EBGP Peer           : 192.168.66.2      AS                  : 38
Enabled             : Yes               OperStatus          : Up
Weight              : 1                 Shutdown-Priority   : 1024
ConnectRetry        : 120               MinAsOrig           : 30
HoldTimeCfg         : 180               KeepaliveCfg        : 60
Source Interface    : Not configured    RRClient            : No
EBGP-Multihop       : No                Remove Private AS   : No
BFD                 : Off               BFD Status          : Not Required
Capabilities Config : ipv4-unicast,ipv4-multicast,4-Byte-As,route-refresh (old & new),l2vpn-evpn
Policy for NLRI Type ipv4-unicast
  In Policy         : None
  Out Policy        : None
  NextHopSelf       : Disabled          Send Communities    : No
  Soft Input Recfg  : Disabled          Allow Looped AS-Path: No
  NextHopUnchanged  : Disabled
Policy for NLRI Type ipv4-vxlan
  In Policy         : None
  Out Policy        : None
  NextHopSelf       : Enabled           Send Communities    : No
Policy for NLRI Type l2vpn-evpn
  In Policy         : None
  Out Policy        : None
  NextHopUnchanged  : Enabled
State               : ESTABLISHED
FSM Up since        : Sat May  5 04:05:30 2018
(Duration: 0:0:08:19)
Remote Addr         : 192.168.66.2      Local Addr          : 192.168.66.1
Remote Port         : 179               Local Port          : 51612
Remote RouterId     : 1.0.0.38          Local RouterId      : 1.0.0.25
HoldTimeNegotiated  : 180               KeepAliveNegotiated : 60
FsmTransitions      : 1
InUpdateElapsedTime : 00:00:08:25       InMsgElapsedTime    : 0:0:08:25
InUpdates           : 2                 OutUpdates (in TxQ) : 3 (0)
InTotalMsgs         : 14                OutTotalMsgs        : 15
InRouteRefreshes    : 0                 OutRouteRefreshes   : 0
Route Statistics for NLRI Type ipv4-unicast
  Received          : 1                 Accepted            : 1
  Rejected          : 0                 Active              : 1
  Suppressed        : 0
Route Statistics for NLRI Type l2vpn-evpn
  Received          : 0                 Accepted            : 0
  Rejected          : 0                 Active              : 0
  Suppressed        : 0
Capabilities Tx     : ipv4-unicast,ipv4-multicast,4-Byte-As,route-refresh (old & new),l2vpn-evpn
Capabilities Rx     : ipv4-unicast,ipv4-multicast,4-Byte-As,route-refresh (old & new),l2vpn-evpn
NLRI for the session:  ipv4-unicast,ipv4-multicast,ipv4-vxlan,l2vpn-evpn
Last State          : ESTABLISHED       Last Event          : RX_KEEP
LastError           : 'Cease - Peer Connection Rejected' (RX) on: Sat May  5 04:05:15 2018
BGP Peer Statistics
  Total Peers       : 1
  EBGP Peers        : 1                 IBGP Peers          : 0
  RR Client         : 0                 EBGP Multihop       : 0
  Enabled           : 1                 Disabled            : 0
The following example displays output for an IPv6 peer:
# show bgp neighbor  3001::1 detail
EBGP Peer           : 3001::1           AS                  : 5
ConnectRetry        : 120               MinAsOrig           : 15
BFD                 : Off               BFD Status          : Inactive
Capabilities Config : ipv6-unicast, ipv6-multicast, 4-Byte-As, route-refresh
Policy for NLRI Type ipv6-unicast
        In Policy         : None
        Out Policy        : None
        RFD HalfLife      : 0m                RFD Reuse           : 0
        RFD Suppress      : 0                 RFD Max-Suppress    : 0m
Policy for NLRI Type ipv6-multicast
        In Policy         : None
        Out Policy        : None
State               : ESTABLISHED
FSM Up  since       : Mon Apr 19 21:20:02 2010 (Duration: 0:0:00:23)
Remote  Addr        : 3001::1           Local Addr          :  3001::6
Remote  Port        : 56539             Local Port          :  179
Remote RouterId     : 1.0.0.5           Local RouterId      : 1.0.0.6
FsmTransitions      : 5
InUpdateElapsedTime : 00:00:00:23       InMsgElapsedTime    : 0:0:00:23
InUpdates           : 1                 OutUpdates (in TxQ) : 4 (0)
InTotalMsgs         : 1                 OutTotalMsgs        : 4
Route Statistics for NLRI Type ipv6-unicast
        Received          : 6
        Accepted          : 6
        Rejected          : 0
        Active            : 6
        Suppressed        : 0
Route Statistics for NLRI Type ipv6-multicast
        Received          : 0
        Accepted          : 0
        Rejected          : 0
        Active            : 0
        Suppressed        : 0
Capabilities Tx     : ipv6-unicast, ipv6-multicast, 4-Byte-AS, route-refresh (old &
new), vpnv4
Capabilities Rx     : ipv6-unicast, ipv6-multicast
NLRI for the session: ipv6-unicast, ipv6-multicast
Error               : 'Hold Timer Expired'                Tx:  3     Rx: 0
Last State          : ESTABLISHED       Last Event          : RX_UPDATE
LastError           : 'Hold Timer Expired' (TX) on: Mon Apr 19 20:50:26 2010
BGP Peer Statistics
  Total Peers       : 1
  Enabled           : 1
  Disabled          : 0
The following example displays show output for transmitted routes:
#show bgp 11.0.0.2 transmitted-routes all
Advertised Routes:
Destination         LPref Weight MED      Peer            Next-Hop        AS-Path
>? 1.1.1.1/32        100                                  11.0.0.1        100
>? 11.0.0.0/24       100                                  11.0.0.1        100
>? 101.0.0.0/24      100                                  11.0.0.1        100
>? 103.0.0.0/24      100                                  11.0.0.1        100
>? 103.0.0.1/32      100                                  11.0.0.1        100
Flags: (*) Preferred BGP route, (>) Active, (d) Suppressed, (h) History
       (s) Stale, (m) Multipath, (u) Unfeasible
Origin: (?) Incomplete, (e) EGP, (i) IGP
BGP Route Statistics
    Advertised Routes : 5
The following example displays show output for rejected routes:
# show bgp 11.0.0.2 rejected-routes all
Rejected Routes:
u ? 1.1.1.1/32      100                                 11.0.0.1        100
    Total Rxed Routes : 5
    Rejected Routes   : 1
    Unfeasible Routes : 1
The following example displays show output for accepted routes:
# show bgp 11.0.0.2 accepted-routes all
Rejected Routes:
    Feasible Routes   : 4
    Active Routes     : 4
The following example shows BGP IPv4 VXLAN routes received from the BGP neighbor located at 192.168.68.1:
# show bgp neighbor 192.168.68.1 ipv4-vxlan received-routes all
Routes:
   LTEP                VNI       Peer        Next-Hop        LPref Weight MED        AS-Path
i  1.0.0.15/32         777       192.168.68.1 192.168.68.1    100   1      0   15
The following example shows L2VPN EVPN accepted and rejected MAC/IP routes for neighbor 192.168.120.119:
 # show bgp neighbor 192.168.120.119 l2vpn-evpn mac-ip received-routes all
     EVPN MAC/IP Routes:
     MAC                  IP                      VNI         Peer              Next-Hop                AS-Path
*>?  RD: 65535:4294967295      ESI: 00:01:02:03:04:05:06:07:08:09
     00:04:96:98:87:62    192.168.110.109         16777215    192.168.120.119   192.168.120.119    50 40 30 20 10
*>i  RD: 4294967295:65535      ESI: 00:01:02:03:04:05:06:07:08:09
     00:04:96:98:87:64    192.168.110.110         777         192.168.120.119   192.168.120.119    50 40 30 20 10
The following example shows all Type 5 received routes to the neighbor at 192.168.99.2:
# show bgp neighbor 192.168.99.2 l2vpn-evpn ip-prefix received-routes all
Routes:
EVPN IP-Prefix Routes:
     IP Prefix/Length                           VNI          Peer                                  Next-Hop           AS-Path
  ?  RD: 1.0.0.25:48        ESI: 00:00:00:00:00:00:00:00:00:00
     125.126.127.128/32                         777          192.168.99.2                          1.0.0.25           38 25
  ?  RD: 1.0.0.25:49        ESI: 00:00:00:00:00:00:00:00:00:00
     1.0.0.0/8                                  778          192.168.99.2                          1.0.0.25           38 25
The any / netMaskLen options were added in ExtremeXOS 11.0.
Support for IPv6 was added in ExtremeXOS 12.6 BGP.
Support for Layer 3 VPNs was added in ExtremeXOS 15.3.
Support for BFD on neighbors was added in ExtremeXOS 21.1
Support for IPv4 VXLAN was added in ExtremeXOS 22.3.
Support for L2VPN EVPN was added in ExtremeXOS 30.2.
Support for EVPN auto-discovery and EVPN Ethernet Segment routes was added in ExtremeXOS 30.4.
Support for Type 5 routes (ip-prefix) was added in ExtremeXOS 30.6.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature, see the Switch Engine v33.6.1 Licensing Guide document.
