show iproute origin
show iproute origin [auto-peering | bgp | blackhole | bootp | direct | ebgp | embgp | ibgp | icmp | imbgp | isis | isis-level-1 | isis-level-1-external | isis-level-2 | isis-level-2-external | mbgp | mpls | evpn {signaling-protocol [ldp | rsvp-te | static]} | ospf | ospf-extern1 | ospf-extern2 | ospf-inter | ospf-intra | rip | static | ospf-inter-vr | direct-inter-vr] {unicast} {vr vrname}
Description
Displays the contents of the IP routing table for routes with the specified origin.
Syntax Description
auto-peering Specifies BGP auto-peering routes.
bgp Specifies BGP routes.
blackhole Specifies blackhole routes.
bootp Specifies BOOTP routes.
direct Specifies direct routes.
ebgp Specifies E-BGP routes.
embgp Specifies EMBGP routes.
ibgp Specifies I-BGP routes.
icmp Specifies ICMP routes.
imbgp Specifies IMBGP routes.
isis Specifies IS-IS routes.
isis-level-1 Specifies IS-IS Level 1 routing.
isis-level-1-external Specifies IS-IS Level 1 External routing.
isis-level-2 Specifies IS-IS Level 2 routing.
isis-level-2-external Specifies IS-IS Level 2 External routing.
mbgp Specifies MBGP routes.
mpls Specifies MPLS routes. This option is available only on platforms that support the MPLS feature pack, which is described in the Switch Engine v33.6.1 Licensing Guide document.
evpn Specifies EVPN routes.
signaling-protocol [ldp | rsvp-te | static] Specifies an MPLS signaling protocol. This option is available only on platforms that support the MPLS feature pack, which is described in the Switch Engine v33.6.1 Licensing Guide document.
ospf Specifies OSPF routes.
ospf-extern1 Specifies OSPF External 1 routing.
ospf-extern2 Specifies OSPF External 2 routing.
ospf-inter Specifies OSPFInter routing.
ospf-intra Specifies OSPFIntra routing.
rip Specifies RIP routes.
static Specifies static routes.
ospf-inter-vr Specifies OSPF Inter-VR routes.
direct-inter-vr Specifies Inter-VR leaked direct routes.
unicast Displays unicast routes with the specified origin.
vrname Specifies a VR or VRF.
Default
N/A.
Usage Guidelines
None.
The following example displays all the BGP routes:
# show iproute origin bgp
The ipv4 keyword was added in ExtremeXOS 11.2.
The embgp, mbgp, and mpls options were added and the ipv4 and multicast options removed in ExtremeXOS 12.2.2.
The evpn option was added in ExtremeXOS 30.7.
The ospf-inter-vr option was added in ExtremeXOS 32.3.
The direct-inter-vr option was added in ExtremeXOS 32.4.
Platform Availability
