Restarts the OpenAPI server process.
N/A.
Use this command to restart the OpenAPI server process. Restarting may be necessary to:
debug openapi configure debug-modeThe restart operation stops and then starts the OpenAPI server process. During the restart, API access via the /rest/openapi URI path will be temporarily unavailable. The server status will show as "Booting" during startup before transitioning to "Healthy" or another operational state.
Service Interruption:
Restarting the OpenAPI server briefly interrupts API access. Schedule restarts during maintenance windows when possible to minimize impact on integrated management tools.
The following command restarts the OpenAPI server:
restart process openapi
Check server status during restart:
show openapi
Sample output during restart:
State : Enabled (by user) Server Status : Booting Version : 1.4.12.16 Schema Version : 0.2.0
Sample output after restart completes:
State : Enabled (by user) Server Status : Healthy Version : 1.4.12.16 Schema Version : 0.2.0
This command was first available in version 33.6.1.
