disable irdp
disable irdp {vlan name}
Description
Disables the generation of ICMP router advertisement messages on one or all VLANs.
Syntax Description
name Specifies a VLAN name.
Default
Disabled.
Usage Guidelines
If no optional argument is specified, all the IP interfaces are affected.
The following example disables IRDP on VLAN "accounting":
disable irdp vlan accounting
Platform Availability
This command is available on all platforms.
