Configures a VLAN as an MVR VLAN.
| vlan-name | Specifies a VLAN name. |
N/A.
Configures MVR on the specified VLAN. When a multicast stream in the specified MVR address range is received on the VLAN, it is leaked to all other VLAN ports where the corresponding IGMP join message is received. By default, the entire multicast address range 224.0.0.0/4, except for the multicast control range 224.0.0.0/24 is used for MVR. To change the MVR address range, use the following command:
configure mvr vlan vlan-name mvr-address {policy-name | none}The following example configures VLAN v1 as an MVR VLAN:
configure mvr add vlan v1
This command was first available in ExtremeXOS 11.4.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the MVR feature, see the Switch Engine v33.6.1 Licensing Guide document.
