disable stacking-support
Description
This command disables the stacking-support option on a switch with dual-purpose hardware.
Syntax Description
This command does not have additional syntax.
Default
Disabled.
Usage Guidelines
The Stacking-Support Option Control column in Switch Support for Alternate Stack Ports displays Yes in the rows for switch configurations for which you can disable the stacking-support option.
After you disable the stacking-support option, you must reboot the switch to activate the configuration change.
If you disable the stacking-support option on a switch and reboot, stacking communication stops and the data ports listed in Switch Support for Alternate Stack Ports use Ethernet protocols instead of stacking protocols.
To disable the stacking ports, enter the following command:
# disable stacking-support
This setting will take effect at the next reboot of this switch.
This command was first available in ExtremeXOS 12.2.
Platform Availability
