configure ospf authentication
configure ospf [vlan [vlan-name | all ] | area area-identifier | virtual-link router-identifier area-identifier] authentication [ none | encrypted simple-password encrypted-simple-password | simple-password { simple-password} | encrypted md5 md5-key-id encrypted-md5-key | md5 md5-key-id { md5-key}]
Description
Specifies the authentication password (up to eight characters) or RSA Data Security, Inc. MD5 Message-Digest Algorithm key for one or all interfaces in a specific area or a virtual link.
Syntax Description
vlan-name Specifies a VLAN name.
all Specifies all VLANs
router-identifier Specifies the router ID of the remote router.
area-identifier Specifies an OSPF area.
encrypted Indicates that the password (or key) is already encrypted (do not use this option).
simple-password Specifies an authentication password (up to 8 ASCII characters).
md5_key_id Specifies a RSA Data Security, Inc. MD5 Message-Digest Algorithm key, from 0-255.
md5_key Specifies a numeric value from 0-65,536. Can also be alphanumeric, up to 26 characters.
none Disables authentication.
Default
N/A.
Usage Guidelines
The md5_key is a numeric value with the range 0 to 65,536 or alphanumeric. When the OSPF area is specified, authentication information is applied to all OSPF interfaces within the area.
The encrypted option is used by the switch when generating a configuration file and when parsing a switch-generated configuration file. Do not select the encrypted option in the CLI.
The following command configures RSA Data Security, Inc. MD5 Message-Digest Algorithm authentication on the VLAN subnet_26:
configure ospf vlan subnet_26 authentication md5 32 test
Platform Availability
This command is available on all platforms with a Base license or higher as described in the licensing guide.
