Configures the OSPF wait interval for a
VLAN or all VLANs.
Syntax Description
vlan-name
Specifies a VLAN name.
all
Specifies all VLANs.
retransmit-interval
Specifies the length of time that the router waits
before retransmitting an LSA that is not acknowledged. The range is
1–3,600.
transit-delay
Specifies the length of time it takes to transmit an
LSA packet over the interface. The range is 1–3,600 seconds.
hello-interval
Specifies the interval at which routers send hello
packets. The range is 1–65,535 seconds.
dead-interval
Specifies the interval after which a neighboring
router is declared down due to the fact that hello packets are no
longer received from the neighbor. The range is
1–2,147,483,647.
wait-timer-interval
Specifies the interval between
the interface coming up and the election of the DR and BDR. Usually
equal to the dead timer interval.
Default
retransmit
interval—5 seconds.
transit
delay—1 second.
hello
interval—10 seconds.
dead
interval—40 seconds.
wait timer
interval—dead interval.
Usage Guidelines
Specify the following:
retransmit interval—If you set an interval that is too
short, unnecessary retransmissions will result.
transit delay—The transit delay must be greater than
0.
hello interval—Smaller times allow routers to discover
each other more quickly, but also increase network traffic.
dead interval—This interval should be a multiple of the
hello interval.
wait timer interval—This interval is required by the
OSPF standard to be equal to the router dead interval. Under some
circumstances, setting the wait interval to smaller values can help OSPF
routers on a broadcast network to synchronize more quickly at the expense of
possibly electing an incorrect DR or BDR. This value should not be set to
less than the hello interval. The default value is equal to the router dead
interval.
The following command
configures the OSPF wait interval on the VLAN accounting:
