Unconfigures a PIM VLAN that has been configured as a border VLAN, which is used to demarcate a PIM domain.
| ipv4 | Configures PIM functionality on IPv4 router interfaces. |
| ipv6 | Configures PIM functionality on IPv6 router interfaces. |
| vlan_name | Specifies a VLAN name. |
By default, no PIM VLANs are configured as border VLANs.
A PIM-SM domain is created by limiting the reach of PIM BSR advertisements. When a border VLAN is configured, PIM BSR advertisements are not forwarded out of the PIM VLAN. Use the unconfigure pim border command to remove the border functionality of the specified PIM VLAN.
The following command unconfigures a PIM border on a VLAN called "vlan_border":
unconfigure pim vlan_border border
This command was first available in ExtremeXOS 12.0.
The IPv6 configuration option was added in ExtremeXOS 15.3.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the PIM feature, see the Switch Engine v33.6.1 Licensing Guide document.
