show mpls exp examination
Description
Displays MPLS EXP value to QoS profile mappings and whether MPLS EXP examination is enabled or disabled.
Syntax Description
This command has no arguments or keywords.
Default
N/A.
Usage Guidelines
This command displays MPLS EXP value to QoS profile mappings and the status of MPLS EXP examination (enabled or disabled). These values are set using the configure mpls exp examination qosprofile command and can be resent using the unconfigure mpls exp examination command.
The following is an example of the output of the show mpls exp examination command:
# show mpls exp examination
EXP --> QoS Profile mapping:
00 --> QP1
01 --> QP2
02 --> QP3
03 --> QP4
04 --> QP5
05 --> QP6
06 --> QP7
07 --> QP8
EXP Examination is disabled
This command was first available in ExtremeXOS 11.6.
Platform Availability
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.6.1 Licensing Guide document.
