configure isis wide-metric
configure isis [vlan all | {vlan} vlan_name] wide-metric metric {level[1 | 2]}
Description
This command sets the wide metric value for one or all IS-IS VLANs.
Syntax Description
vlan all Applies the configuration to all IS-IS VLANs.
vlan_name Specifies a single VLAN to which the configuration applies.
metric Sets the metric. The range is 1 to 16777214.
level [1 | 2] Limits the configuration change to either level 1 or level 2. If neither level 1 nor level 2 is specified, the configuration applies to both levels.
Default
10.
Usage Guidelines
If the wide metric style is enabled on the associated IS-IS router process, the wide metric value is used in Extended IP reachability TLVs, Extended IS Reachability TLVs, and IPv6 Reachability TLVs in LSPs.
The following command sets the wide metric to 15 for all IS-IS VLANs:
configure isis vlan all wide-metric 15
Platform Availability
This command is available on all platforms with a Premier or Extreme Platform ONE license as described in the licensing guide.
