show upm profile
show upm profile name
Description
Displays a list of the UPM profiles on the system and some of their configuration information, or the contents of a specified profile.
Syntax Description
name Displays the contents of the specified profile.
Default
N/A.
Usage Guidelines
To see a list of all UPM profiles on a switch, use the command without the name option. The resulting display shows the names of the profiles on the system and their status, active or disabled.
Use the name option to see the contents of a specific profile.
The output of the command is similar to the following:
* BD-8808.36 # show upm profile
UPM Profile Events Ports Flags
p1 UPM Timer(t1) e
p1 device detect 1:1 e
p2 e
Number of UPM Profiles: 2
Number of UPM Events in Queue for execution: 0
Flags: d - disabled, e - enabled
Event name: log-message(Log filter name) - Truncated to 20 chars
* BD-8808.37 # show upm profile "p1"
Created at : 2010-04-11 04:07:41
************Profile Contents Begin************
ena por 1:1
************Profile Contents Ends*************
Profile State: Enabled
Profile Maximum Execution Time: 30
Events and ports configured on the profile:
Event                           Port list/Log filter
device-detect              1:1
device-undetect             :
user-authenticated          :
user-unauthenticated        :
This command was first available in ExtremeXOS 11.6.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the Universal Port feature, see the Switch Engine v33.6.1 Licensing Guide document.
