Disables RIPng from redistributing routes from other routing protocols.
| direct | Specifies directly reachable subnets from the router (only interfaces that have IP forwarding enabled are exported). |
| ospfv3 | Specifies all OSPFv3 routes. |
| ospfv3-extern1 | Specifies OSPFv3 external route type 1. |
| ospfv3-extern2 | Specifies OSPFv3 external route type 2. |
| ospfv3-inter | Specifies OSPFv3-inter area routes. |
| ospfv3-intra | Specifies OSPFv3-intra area routes. |
| static | Specifies user configured static routes. |
| isis | Specifies IS-IS routes. |
| isis-level-1 | Specifies IS-IS Level 1 routes. |
| isis-level-1-external | Specifies IS-IS Level 1 External routes. |
| isis-level-2 | Specifies IS-IS Level 2 routes. |
| isis-level-2-external | Specifies IS-IS Level 2 External routes. |
| bgp | Specifies BGP IPv6 routes |
| e-bgp | Specifies EBGP routes. |
| i-bgp | Specifies IBGP routes. |
Disabled.
This command disables the exporting of static, direct, IS-IS, and OSPF-learned routes from the switch routing table into the RIPng domain.
The following command disables RIPng from redistributing any routes learned from OSPFv3:
disable ripng export ospfv3
This command is available on all platforms.
