configure ospfv3 authentication (IPsec)
configure ospfv3 [{vlan} vlan-name | {tunnel} tunnel-name] authentication [none |ipsec spi spi esp-auth-algorithm algorithm key [key-string | encrypted encrypted-key-string]
Description
Configures Internet Protocol Security (IPsec) with a manual key to provide authentication on OSPFv3 interfaces.
Syntax Description
ospfv3 Specifies OSPFv3 interface.
vlanSpecifies OSPFv3 VLAN.
vlan-nameSpecifies an IPv6 configured VLAN.
tunnelSpecifies Layer 3 tunnel.
tunnel-nameSpecifies an Layer 3 tunnel name.
authenticationSpecifies interface authentication.
noneSpecifies no authentication (default).
ipsec spiSpecifies the authentication type is IPsec Encapsulating Security Payload (ESP) with manual key.
spiSpecifies Security Parameter Index value. Range is 256-4294967295.
esp-auth-algorithmSpecifies the ESP Authentication algorithm.
algorithm
Specifies the authentication algorithm.
Supported authentication algorithms are hmac-sha-1 and hmac-sha-256.
keySpecifies the authentication key.
key-string
Specifies the key string in clear text.
Both the ASCII string and hexadecimal string are supported, and hexadecimal string must begin with “0x”.
encryptedSpecifies that the key string is in encrypted format.
Specifies the encrypted key string.
The encrypted key string must be enclosed in double quotes.
Default
If not specified, no authentication is applied.
Usage Guidelines
When configuring IPsec with manual key on an OSPFv3 VLAN, the exact same IPsec parameters (SPI, algorithm and key-string) must be specified on all routers connected to that VLAN.
To configure OSPFv3 virtual link authentication, run the command ospfv3 virtual-link {routerid} router-identifier {area} area-identifier authentication [none | ipsec spi spi esp-auth-algorithm algorithm key [key-string | encrypted encrypted-key-string].
The following example for VLAN "v1" applies authentication type IPsec with SPI "551" and algorithm "hmac-sha-256" with key "mykey":
# configure ospfv3 vlan v1 authentication ipsec spi 551 esp-auth-algorithm hmac-sha-256 key mykey
This command was first available in ExtremeXOS 31.2.
Platform Availability
This command is available on all platforms with a Base license or higher as described in the licensing guide.
