Displays per-port MKA and MAC Security (MACsec) data in tabular format.
| ports | Specifies ports to show information on. |
| port_list | Lists which ports to view MACsec information on. |
| usage | Specifies to display per-port MACsec usage information. |
N/A.
This commands displays a table containing both control-layer (MKA) status and data-layer (MACsec) statistics:
ExtremeXOS never chooses ‘Unauthenticated‘ or ‘Authenticated‘ access, but these options are allowed by the IEEE802.1X-2010 standard, so these cases may arise when interoperating with MKA/MACsec devices from other vendors.
To accommodate the width of the page, the MACsec columns are shown below the MKA content. In the actual output from the command, these columns appear beside each other.# show macsec ports 25,50
MAC Security
-----------------MKA---------------------
Local Peer
MACsec Message Message Peer Connect Key
Port Enabled Number Number Status Status Server
25 Yes 0 - N/A PENDING None
50 Yes 162244 162361 L SECURE Peer
MAC Security
---------SecY-Tx-SC----SecY-Rx-SC------
Local Peer
Encrypted Octets OK Octets
Packets Encrypted Packets Decrypted
1658 79584 2318 55827
The following example shows MACsec usage on ports 1-2 and 49-56:
# show macsec ports 1-12,49-56 usage
Subject
Link to BW MACsec Allocated
Port Speed Maximum? Enabled Bandwidth
1 1.0Gbps Yes Yes 1.0Gbps
2 1.0Gbps Yes Yes 1.0Gbps
3 1.0Gbps Yes Yes 1.0Gbps
4 1.0Gbps Yes Yes 1.0Gbps
5 1.0Gbps Yes Yes 1.0Gbps
6 1.0Gbps Yes Yes 1.0Gbps
7 1.0Gbps Yes Yes 1.0Gbps
8 1.0Gbps Yes Yes 1.0Gbps
9 1.0Gbps Yes Yes 1.0Gbps
10 1.0Gbps Yes Yes 1.0Gbps
11 1.0Gbps Yes No -
12 1.0Gbps Yes No -
49 10.0Gbps Yes No -
50 10.0Gbps Yes No -
51 10.0Gbps Yes No -
52 10.0Gbps Yes No -
53 10.0Gbps Yes Yes 10.0Gbps
55 10.0Gbps Yes No -
This command was first available in ExtremeXOS 30.1.
The usage option was first available in ExtremeXOS 31.5
This command is available on the following platforms.
The MACsec feature requires the installation of the MAC Security feature pack license.| Platform | Ports |
| 5120 | All ports of all models except stacking ports. |
| 5320 | All ports of all models except stacking ports. |
| 5420 | All ports of all models except stacking ports. |
| 5520 | All ports, except 5520-VIM-4X and 5520-24X 10G ports |
| 5720 | All ports of all models except stacking ports. |
| Extreme 7520-48YE-8CE | All front-panel ports. |
