Displays RIP specific configuration.
N/A.
None.
The following command displays RIP specific configuration:
# show rip
The following is sample output from this command:
# show rip RIP Routing : Disabled Operational status: Down Split Horizon : Enabled Poison Reverse : Enabled Triggered Updates: Enabled Aggregation : Disabled Update Interval : 30 Route Timeout : 180 Garbage Timeout : 120 Router Alert : Disabled Originate Default: Disabled Sys Import-Policy: None Redistribute: Protocol Status Cost Tag Policy ----------------------------------------------------------- Direct Disabled 0 0 none Static Disabled 0 0 none OSPFIntra Disabled 0 0 none OSPFInter Disabled 0 0 none OSPFExt1 Disabled 0 0 none OSPFExt2 Disabled 0 0 none E-BGP Disabled 0 0 none I-BGP Disabled 0 0 none ISISL1 Disabled 0 0 none ISISL2 Disabled 0 0 none ISISL1Ext Disabled 0 0 none ISISL2Ext Disabled 0 0 none
This command is available on all platforms with a Base license or higher as described in the licensing guide.
