delete macsec connectivity-association
delete macsec connectivity-association ca_name
Description
Deletes a previously created connectivity-association (CA) object that holds MAC Security (MACsec) key authentication data.
Syntax Description
connectivity-association Secures connectivity provided between MACsec stations.
ca_name Selects the CA to delete.
Default
N/A.
Usage Guidelines
Prior to deletion, ports assigned to the CA must be removed with the configure macsec connectivity-association ca_name [pre-shared-key {ckn ckn} {cak [encrypted encrypted_cak] | cak} | ports [port_list] [enable | disable]] command using the disable option.
The following example deletes the CA "testca":
# delete macsec connectivity-association testca
This command was first available in ExtremeXOS 30.1.
Platform Availability
This command is available on the following platforms.
The MACsec feature requires the installation of the MAC Security feature pack license.
PlatformPorts
5120All ports of all models except stacking ports.
5320All ports of all models except stacking ports.
5420All ports of all models except stacking ports.
5520All ports, except 5520-VIM-4X and 5520-24X 10G ports
5720All ports of all models except stacking ports.
Extreme 7520-48YE-8CEAll front-panel ports.
