disable ripng triggerupdate
disable ripng triggerupdate {vlan vlan-name | tunnel tunnel_name | [vlan | tunnel] all}
Description
Triggered updates are a mechanism for immediately notifying a router‘s neighbors when the router adds or deletes routes or changes their metric. This command disables the trigger update mechanism.
Syntax Description
vlan-name Specifies an IPv6 configured VLAN.
tunnel_name Specifies an IPv6 tunnel.
all Specifies all interfaces.
Default
Enabled.
Usage Guidelines
Triggered updates occur whenever a router changes the metric for a route and it is required to send an update message immediately, even if it is not yet time for a regular update message to be sent. This will generally result in faster convergence, but may also result in more RIPng-related traffic.
When this feature is disabled, any metric change on the interface, or an interface going down will not be communicated until the next periodic update. To configure how often periodic updates are sent, use the following command:
configure ripng updatetime
The following command disables the trigger update mechanism:
Platform Availability
This command is available on platforms with an Edge, Advanced Edge, or Core license. For licensing information, see the Switch Engine v33.6.1 Licensing Guide document.
