configure msrp sharing
configure msrp sharing [all | port_list] bandwidth [cumulative | single-port] percentage
Description
This command configures the LAG bandwidth mode as either cumulative or master-port only.
Syntax Description
all All the ports in the switch.
port_list Port list separated by a comma or -
cumulative Use bandwidth of a single port, plus a percentage of bandwidth of every other LAG member port in the group.
single-port Use bandwidth of a single port only for the entire LAG.
percentage Percentage of bandwidth of each LAG port to be added to master port bandwidth.
Default
Single-port.
Usage Guidelines
If cumulative mode is selected, the percentage is also configured.
This CLI command displays bandwidth information of an MSRP port.
# show msrp ports bandwidth
Port       Port  Class    Delta    Maximum   Reserved   Available
          Speed                    Effective
5ab          0 M A          75.00%   0.00%       0.00%      0.00%
                 B           0.00%   0.00%       0.00%      0.00%
*21ab     1000 M A          75.00%   75.00%      0.00%     75.00%
                 B           0.00%   75.00%      0.00%     75.00%
Flags: (*) Active, (!) Administratively disabled,
       (a) SR Class A allowed, (b) SR Class B allowed.
This command was first available in ExtremeXOS 21.1.
Platform Availability
This command is available on platforms that support the AVB feature pack license and have it installed. For complete information about software licensing, including how to obtain and upgrade your license, and which platforms support the AVB feature, see the Switch Engine v33.6.1 Licensing Guide document.
