Displays global OSPF information.
This command has no keywords or arguments.
N/A.
Not applicable.
The following command displays global OSPF information:
show ospf
The following is sample output from this command:
OSPF : Disabled MPLS LSP as Next-Hop: No RouterId : 0.0.0.0 RouterId Selection : Automatic InstanceId : 22 ASBR : No ABR : No ExtLSA : 0 ExtLSAChecksum : 0x0 OriginateNewLSA : 0 ReceivedNewLSA : 0 SpfHoldTime : 3 Lsa Batch Interval : 30s CapabilityOpaqueLSA : Enabled 10M Cost : 22 100M Cost : 20 1000M Cost (1G) : 19 2500M Cost (2.5G) : 18 5000M Cost (5G) : 17 10000M Cost (10G) : 16 25000M Cost (25G) : 15 40000M Cost (40G) : 13 50000M Cost (50G) : 12 100000M Cost (100G) : 10 ASExternal LSALimit : Disabled Timeout (Count) : Disabled (0) Originate Default : Enabled Always : Yes Type: 2 Cost: 10 Tag: 0 SNMP Traps : Enabled SNMP Trap Bit Map : 0xffff VXLAN Extensions : Enabled Redistribute: Protocol Status cost Type Tag Policy direct Disabled 0 0 0 None direct-inter-vr Enabled 30 1 0 None static Disabled 0 0 0 None rip Disabled 0 0 0 None e-bgp Disabled 0 0 0 None i-bgp Disabled 0 0 0 None isis-level-1 Disabled 0 0 0 None isis-level-2 Disabled 0 0 0 None isis-level-1-external Disabled 0 0 0 None isis-level-2-external Disabled 0 0 0 None host-mobility Enabled 0 2 0 None # of Inter-VR Exports: 3
The SNMP Traps and 40G parameters were added in ExtremeXOS 12.6.
This command is available on all platforms.
