configure bgp evpn l3vni
configure bgp evpn l3vni [vni_value | none] vr vr_name
Description
Configures a Layer 3 virtual network identifier (VNI) and binds it to a VPN virtual router interface (VRF).
Syntax Description
bgp Specifies changing the BGP configuration.
evpn Specifies changing the EVPN configuration.
l3vni Specifies changing the integrated routing and bridging IP VRF VNI configuration.
vni_value Sets the VNI to a value between 1 and 16,777,215.
none Removes an existing VNI setting for this EVPN L3VNI.
vr Specifies binding the VNI to a VRF.
vr_name Sets the VRF name.
Default
N/A.
The following example binds VNI 100 to VRF "vrf1":
# configure bgp evpn l3vni 100 vr vrf1
This command was first available in ExtremeXOS 30.6.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature, see the Switch Engine v33.6.1 Licensing Guide document.
