configure macsec cipher-suite
configure macsec cipher-suite [gcm-aes-128 | gcm-aes-256] ports port_list
Description
Configures the preferred cipher suite for MAC Security (MACsec).
Syntax Description
cipher-suite Selects provisioning MACsec cipher suite to be used if elected as key server.
gcm-aes-128 Galois/Counter Mode of AES-128 symmetric block cipher (Default).
gcm-aes-256 Galois/Counter Mode of AES-256 symmetric block.
ports Specifies configuring ports.
port_list Lists which ports to configure the selected cipher suite on.
Default
The cipher suite gcm-aes-128 is selected by default.
Usage Guidelines
Table 1. Cipher Support
GCM-AES-256 and GCM-AES-128
Ports with LRM/MACsec Adapter
ExtremeSwitching 5320 (except 5320-24X-4X-XT), 5420, 5720 on all ports.
ExtremeSwitching 5520 on all ports, except 5520-VIM-4X and 24X 10G ports.
If GCM-AES-256 is desired between two switches using the LRM/MACsec Adapter, you need to issue this command on at least the key server side, but preferably on both sides.
If the port is elected as MKA key server, then the configured cipher suite is used to protect all port traffic. If the peer port is elected as MKA key server, then the peer chooses which cipher suite to use.
The following example selects the gcm-aes-256 cipher suite on ports 22, 30–33:
# configure macsec cipher-suite gcm-aes-256 22,30-33
The following example selects the gcm-aes-128 cipher suite on port 30:
# configure macsec cipher-suite gcm-aes-128 30
This command was first available in ExtremeXOS 30.2.
Platform Availability
This command is available on the following platforms.
The MACsec feature requires the installation of the MAC Security feature pack license.
PlatformPorts
5120All ports of all models except stacking ports.
5320All ports of all models except stacking ports.
5420All ports of all models except stacking ports.
5520All ports, except 5520-VIM-4X and 5520-24X 10G ports
5720All ports of all models except stacking ports.
Extreme 7520-48YE-8CEAll front-panel ports.
