show iproute protection ping
show iproute {ipv4 | ipv6} protection ping {v4_or_v6_gateway} {vr vr_name} {detail}
Description
Displays the current ping protection state for IPv4 or IPv6 routes, along with the number of protected routes. The information can be displayed per gateway, or for all gateways in a given VR.
Syntax Description
ipv4 Specifies IPv4 routes (default).
ipv6 Specifies IPv6 routes.
protection pingSpecifies protection ping information.
v4_or_v6_gatewayName of the specific IPv4 or IPv6 gateway to show protected routes for.
vr vr_nameShows all protected routes for the specified VR.
detailDisplays timestamps of the last time each gateway transitioned to the "up" state and to the "down" state.
Default
If not specified, IPv4 is the default.
The following example shows all ping protected IPv4 routes only:
# show iproute protection ping
Ping protection for static IPv4 routes : Enabled
                              Interval : 2
                              Misses   : 3
Gateway          State  # Routes  VR
1.2.3.4          Down          1  VR-Default
1.2.3.5          Up            1  VR-Default
The following example shows ping protected IPv6 routes only:
# show iproute ipv6 protection ping
Ping protection for static IPv6 routes : Enabled
                              Interval : 2
                              Misses   : 3
2000:2000:2000:2000:2000:2000:2000:2001  Up            2  VR-Default
3000::2                                  Down          2  VR-Default
The following example shows ping protected IPv6 routes with gateway up/down transition timestamp information:
# show iproute ipv6 protection ping detail
                              Interval : 2
                              Misses   : 3
Gateway:   2000:2000:2000:2000:2000:2000:2000:2001
State:     Up
# Routes:  2
VR:        VR-Default
Last Up:   Thu Mar 31 22:44:12 2016
Last Down: Thu Mar 31 22:42:22 2016
Gateway:   3000::2
State:     Down
# Routes:  2
VR:        VR-Default
Last Up:   --
This command was first available in ExtremeXOS 22.1.
Platform Availability
