Configures the cost of one or all interface(s).
| vlan_name | Specifies an IPv6 configured VLAN. |
| tunnel_name | Specifies an IPv6 tunnel. |
| all | Specifies all IPv6 configured VLANs or all IPv6 tunnels. |
| automatic | Determine the advertised cost from the OSPFv3 metric table. |
| cost | Specifies the cost metric. Range is 1 to 65535. |
The default cost is automatic.
Use this command to set the cost of an interface (a VLAN or tunnel) manually, if the default cost needs to be overwritten. The interface cost is advertised as the link cost in router-LSA.
The following command configures the cost metric of the VLAN accounting:
configure ospfv3 vlan accounting cost 10
This command is available on all platforms with a Base license or higher as described in the licensing guide.
