configure tacacs-accounting server
configure tacacs-accounting [primary | secondary] server [ipaddress | hostname] {udp_port} client-ip ipaddress {vr vr_name}
Description
Configures the TACACS+ accounting server.
Syntax Description
primary Configures the primary TACACS+ accounting server.
secondary Configures the secondary TACACS+ accounting server.
ipaddress The IP address of the TACACS+ accounting server being configured.
hostname The host name of the TACACS+ accounting server being configured.
tcp_port The TCP port to use to contact the TACACS+ server.
ipaddress The IP address used by the switch to identify itself when communicating with the TACACS+ accounting server.
vr_name Specifies the virtual router on which the client IP is located.
Note: User-created VRs are supported only on the platforms listed for this feature in the Switch Engine v33.6.1 Licensing Guide document.
Default
Unconfigured. The default virtual router is VR-Mgmt, the management virtual router.
Usage Guidelines
You can use the same TACACS+ server for accounting and authentication.
To remove a server, use the following command:
unconfigure tacacs server [primary | secondary]
IPv6 Address Validation: The following IPv6 address types are not allowed for TACACS+ server configuration:
The following command configures server tacacs1 as the primary TACACS+ accounting server for client switch 10.10.20.35 using a virtual router interface of VR-Default:
configure tacacs-accounting primary server tacacs1 client-ip 10.10.20.35 vr vr-Default
Platform Availability
