configure bgp cluster-id
configure bgp cluster-id cluster-id
Description
Configures the local cluster ID.
Syntax Description
cluster-id Specifies a 4 byte field used by a route reflector to recognize updates from other route reflectors in the same cluster. The range is 0 - 4294967295.
Default
N/A.
Usage Guidelines
BGP must be disabled before the cluster ID can be changed.
Used when multiple route reflectors are used within the same cluster of clients.
The following command appends a BGP route reflector cluster ID to the cluster list of a route:
configure bgp cluster-id 40000
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature, see the Switch Engine v33.6.1 Licensing Guide document.
