show ntp server
show ntp server detail
Description
Shows the NTP servers configured on the switch, including the name, IP address, key ID, and index.
Syntax Description
detailSpecifies detailed NTP Server and Peer configuration information.
Default
N/A.
Usage Guidelines
N/A.
The following command shows the NTP servers configured on the switch:
# show ntp server
VR Name               Name                      IP Address           Type      Flags  Key    Ver
VR-Default            1.1.1.1                   1.1.1.1              Server    -      65534  3
VR-Mgmt               10.127.11.246             10.127.11.246        Server    -      200    3
Flags: (I) Initial Burst, (B) Burst
The following command shows detailed NTP Server and Peer configuration information:
# show ntp server detail
IP Address         : 1.1.1.1
VR Name            : VR-Default
Type               : Server
Burst Type         : -
Key Number         : -
NTP Version        : 3
Min Poll           : 4 (16 seconds)
Max Poll           : 12 (4096 seconds)
IP Address         : 2.2.2.2
Type               : Server
Burst Type         : Burst
Key Number         : -
NTP Version        : 3
Min Poll           : 7 (128 seconds)
Max Poll           : 8 (256 seconds)
IP Address         : 3.3.3.3
Type               : Server
Burst Type         : Initial Burst
Key Number         : -
NTP Version        : 3
IP Address         : 4.4.4.4
Type               : Server
Burst Type         : -
Key Number         : 1
NTP Version        : 3
Min Poll           : 9 (512 seconds)
Max Poll           : 17 (131072 seconds)
IP Address         : 0.0.0.0
Type               : Server
Burst Type         : -
Key Number         : -
NTP Version        : 3
Min Poll           : 5 (32 seconds)
Max Poll           : 10 (1024 seconds)
This command was first available in ExtremeXOS 12.7.
Platform Availability
