show vm guest interfaces
show vm vm_name guest interfaces
Description
Shows the interfaces of a running guest virtual machine (VM).
Syntax Description
vm Designates a virtual machine.
vm_nameSpecifies the VM name to show interfaces for.
guestSpecifies guest OS viewpoint.
interfacesSpecifies interfaces and addresses.
Default
N/A.
Usage Guidelines
The Integrated Application Hosting (IAH) feature requires the Solid State Storage Device SSD-120.
For this command to work, qemu guest agent must be running on the guest VM.
The following example shows the interfaces for VM "vm1":
# show vm vm1 guest interfaces
Name       MAC address          Protocol     Address
lo         00:00:00:00:00:00    ipv4         127.0.0.1/8
-          -                    ipv6         ::1/128
ens8       52:54:00:d4:88:59    ipv4         10.68.13.7/24
-          -                    ipv6         fe80::5054:ff:fed4:8859/64
ens6       00:11:88:fe:ab:75    ipv4         192.168.1.5/24
-          -                    ipv6         fe80::211:88ff:fefe:ab75/64
ens7       00:11:88:fe:ab:76    ipv4         192.168.0.5/24
-          -                    ipv6         fe80::211:88ff:fefe:ab76/64
This command was first available in ExtremeXOS 30.3.
Platform Availability
This command is available on all platforms that support the Integrated Application Hosting (IAH) feature and have a Premier or Extreme Platform ONE license installed. For a list of platforms that support the IAH feature and for information about licenses, see the Switch Engine v33.6.1 Licensing Guide .
