disable openapi
disable openapi
Description
Disables the OpenAPI server process.
Syntax Description
Default
N/A.
Usage Guidelines
Use this command to disable the OpenAPI server when it is not needed. Disabling the server stops the OpenAPI process and prevents API access via the /rest/openapi URI path.
IQAgent Override:
When IQAgent is enabled, the OpenAPI server is required for cloud connectivity and cannot be disabled by the user. Attempting to disable the server when IQAgent is enabled displays the following message:
Note: The OpenAPI server is required by IQAgent and will remain operational
while IQAgent is enabled.
The server will remain running and the state will show as "Enabled (by IQAgent)" even after issuing the disable command. To disable the OpenAPI server when IQAgent is enabled, you must first disable IQAgent.
Configuration Persistence:
The OpenAPI server enable/disable state persists across reboots.
The following command disables the OpenAPI server:
disable openapi
Verify the server is disabled:
show openapi
Sample output:
State            : Disabled
Server Status    : Stopped
Version          : 1.4.12.16
Schema Version   : 0.2.0
Attempting to disable when IQAgent is enabled:
disable openapi
This command was first available in version 33.6.1.
Platform Availability
