Shows rendezvous point (RP) for Anycast RP using PIM (RFC 4610) information.
| ipv4 | Specifies IPv4 address family. |
| ipv6 | Specifies IPv6 address family. |
| anycast-rp | Shows Anycast RP information. |
| ip_address | Shows information for a specific Anycast RP. |
N/A.
The Anycast RP using PIM feature provides fast convergence when RP routers fail using PIM protocol without using the source discovery protocol Multicast Source Discovery Protocol (MSDP) for both IPv4 and IPv6 address families.
To configure or remove RPs, use the configure pim {ipv4 | ipv6} anycast-rp ip_address [policy | none] command.
The following example shows information for all Anycast RP:
# show pim anycast-rp
Anycast RP Policy
Peer's Address Reg/Stop In Reg/Stop Out
150.150.150.1 pim-domain1-v4-anycast-rp
10.10.10.1* 50 50
20.20.20.1 45 100
30.30.30.1 45 56
100.100.100.1 pim-domain1-v4-anycast-rp
10.10.10.1* 0 0
20.20.20.1 0 0
30.30.30.1 0 0
Total number of anycast RP: 2
* Indicates local address
The following example shows information for all Anycast RP at IPv6 addresses:
# show pim ipv6 anycast-rp
Anycast RP Policy
2002:db8:85a3::8a2e:370:7334 pim-domain1-v6-anycast-rp
2001:db8:85a3::8a2e:370:7334* 50 50
2001:db8:85a3::8a2e:370:7335 45 100
2001:db8:85a3::8a2e:370:7336 45 56
2001:db8:85a3::8a2e:370:7337 45 56
3002:db8:85a3::8a2e:370:7334 pim-domain2-v6-anycast-rp
3001:db8:85a3::8a2e:370:7334* 50 50
3001:db8:85a3::8a2e:370:7335 45 100
3001:db8:85a3::8a2e:370:7336 45 56
The following example shows information for the Anycast RP at IPv6 address 2001:0db8:85a3:0000:0000:8a2e:0370:7334:
# show pim ipv6 anycast-rp 2002:0db8:85a3:0000:0000:8a2e:0370:7334
Anycast RP Policy
This command was first available in ExtremeXOS 31.1.
This command is available on platforms that support the appropriate license for the PIM feature. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the PIM feature, see the Switch Engine v33.6.1 Licensing Guide .
