enable iproute protection ping
enable iproute {ipv4 | ipv6} protection ping
Description
Globally enables ping protection for static routes added with ping protection for IPv4 and IPv6.
Syntax Description
ipv4 Specifies IPv4 (default).
ipv6 Specifies IPv6.
protectionEnables route protection.
pingGlobally enables ping protection for static routes added with ping protection (default is enabled).
Default
Enabled is the default. If not specified, IPv4 is the default.
The following example enables ping protection for static routes added with ping protection for IPv4:
# enable iproute ipv4 protection ping
This command was first available in ExtremeXOS 22.1.
Platform Availability
This command is available on all platforms with a Base license or higher as described in the licensing guide.
