show bgp routes
For IPv4 and IPv6 address families:
show bgp routes {address-family [ipv4-unicast | ipv4-multicast |ipv6-unicast | ipv6-multicast | ipv4-vxlan | {l2vpn-evpn [inclusive-multicast | mac-ip | auto-discovery | esi | ip-prefix]}]} {detail} [ipv4-vxlan | all | as-path path-expression | community [no-advertise | no-export | no-export-subconfed | number community_number | autonomous-system-idbgp-community] | network [any/netMaskLen | networkPrefixFilter] {exact}] {vr vr_name}
For the VPNv4 address family:
show bgp routes address-family vpnv4 {detail} [all | as-path path-expression | community [no-advertise | no-export | no-export-subconfed | number community-number |autonomous-system-idbgp-community] |rd rd network [any/netMaskLen |networkPrefixFilter] {exact}] {vr vr_name}
Description
Displays the BGP route information base (RIB).
Syntax Description
ipv4-unicast
Specifies the IPv4 unicast address family.
ipv4-multicast
Specifies an IPv4 multicast address family.
ipv6-unicast
Specifies the IPv6 unicast address family.
ipv6-multicast
Specifies an IPv6 multicast address family.
ipv4-vxlan Specifies an IPv4 VXLAN address family.
l2vpn-evpn Specifies an L2VPN EVPN address family.
inclusive-multicast Displays EVPN inclusive-multicast (type 3) routes
mac-ip Displays EVPN MAC/IP (type 2) routes.
auto-discovery Displays EVPN auto-discovery (type 1) routes.
esi Displays EVPN Ethernet segment (type 4) routes.
ip-prefix Displays EVPN ip-prefix (type 5) routes.
vpnv4
Specifies the VPNv4 address family for Layer 3 VPN support.
all
Specifies all routes.
path-expression
Displays routes that match the specified AA path expression.
no-advertise
Specifies the no-advertise community attribute.
no-export
Specifies the no-export community attribute.
no-export-subconfed
Specifies the no-export-subconfed community attribute.
community_number
Specifies a community number.
Specifies an autonomous system ID (0-65535).
bgp-community
Specifies the BGP community number.
rd
Specifies the Route Distinquisher (RD) value for the Layer 3 VPN routes for which you want to clear flap statistics.
any
Specifies all routes with a given or larger mask length.
netMaskLen
Specifies a IPv4 or IPv6 subnet mask length (number of bits).
networkPrefixFilter
Specifies an IPv4 or IPv6 address and netmask.
exact
Specifies an exact match with the IP address and subnet mask.
vr Specifies viewing routes associated with a specified virtual router.
vr_name Specifes the VR name. If not specified, the VR of current command context is used.
Default
If no address family is specified, IPv4 unicast is the default.
Usage Guidelines
The option network any / netMaskLen displays all BGP routes whose mask length is equal to or greater than maskLength, irrespective of their network address.
The option network any / netMaskLen exact displays all BGP routes whose mask length is exactly equal to maskLength, irrespective of their network address.
To display Layer 3 VPN information, you must enter this command in the context of on the MPLS-enabled VR; it is not supported for BGP neighbors on the CE (VRF) side of the PE router.
You can only execute the show for vpnv4 address family in a VR context. If you execute this command in a VRF context, the “Cannot execute command in VRF context” error is displayed.
This command applies to the current VR or VRF context.
If you do not specify an address family, this command applies to the IPv4 unicast address family. To apply this command to an address family other than the IPv4 unicast address family, you must specify the address family.
The following command displays detailed information about all BGP routes:
* Switch.5 #  show bgp routes all
Received Routes:
Destination         LPref Weight MED     Peer            Next-Hop        AS-Path
*>? 1.1.1.1/32      100   0              11.0.0.1        11.0.0.1        100
* ? 11.0.0.0/24     100   0              11.0.0.1        11.0.0.1        100
*>? 101.0.0.0/24    100   0              11.0.0.1        11.0.0.1        100
u ? 103.0.0.0/24    100   0              11.0.0.1        11.0.0.1        100
Flags: (*) Preferred BGP route, (>) Active, (d) Suppressed, (h) History
       (s) Stale, (m) Multipath, (u) Unfeasible
Origin: (?) Incomplete, (e) EGP, (i) IGP
BGP Route Statistics
  Total Rxed Routes : 4
  Feasible Routes   : 3
  Active Routes     : 2
  Rejected Routes   : 0
  Unfeasible Routes : 1
Route Statistics on Session Type
  Routes from Int Peer: 4
     Routes from Ext Peer: 0
The following example displays a detailed show output:
Route:  11.0.0.0/24,  Peer 11.0.0.1, Unfeasible
Origin Incomplete, Next-Hop 11.0.0.1, LPref 100, MED 0
Weight 0, RR Orig ID 0.0.0.0
AS-Path: 100
DampInfo: Penalty 0 Flapped 0 times in 00:10:47
  Total Rxed Routes : 1
  Feasible Routes   : 0
  Active Routes     : 0
  Rejected Routes   : 5
  Routes from Int Peer   : 5
  Routes from Ext Peer   : 0
The following command displays BGP information for the IPv6 address family:
Switch.21 #   show bgp routes address-family ipv6-unicast all
Received Routes:
*>? 2001::/64                             100           0          120
    3000::1                               3001::1       100,       200
Origin: (?)
    Feasible Routes   : 1
    Active Routes     : 1
    Rejected Routes   : 0
    Unfeasible Routes : 0
    Routes from Int Peer: 1
The following example displays detailed show output for the IPv6 address family:
switch.21 # show bgp routes address-family ipv6-unicast all
Route: 2001::/64, Peer 3000::1,
Unfeasible, Origin Incomplete,
Next-Hop 3001::1,
LPref 100, MED 0,
AS-Path: 100
Route: 2002::/64, Peer 3000::1,
Active, Origin Incomplete,
Next-Hop 3001::1,
LPref 100, MED 0,
AS-Path: 100
    Total Rxed Routes : 2
    Feasible Routes   : 1
    Active Routes     : 1
    Rejected Routes   : 0
    Routes from Int Peer: 2
The following examples display detailed show output for the IPv4 address family:
switch.21  # show bgp routes address-family vpnv4 all
Received Routes:
*>? 100:1:10.0.0.0/8                                 100    0      120
    11.0.0.2                                         11.0.0.2
    100, 200
    Feasible Routes   : 1
    Active Routes     : 1
    Rejected Routes   : 0
Route: 100:1:10.0.0.0/8, Peer 11.0.0.2,
Next-Hop 11.0.0.2,
LPref 100, MED 0,
AS-Path:  100
    Feasible Routes   : 0
    Active Routes     : 0
    Rejected Routes   : 0
The following example displays detailed show output for the IPv4 VXLAN address family:
# show bgp routes ipv4-vxlan all
Routes:
     LTEP                VNI       Peer         Next-Hop      LPref Weight MED        AS-Path
* i  1.0.0.15/32         777       192.168.68.1 192.168.68.1    100   1      0          15
The following example displays L2VPN EVPN MAC/IP routes:
 # show bgp routes l2vpn-evpn mac-ip all
     EVPN MAC/IP Routes:
     MAC                  IP                      VNI         Peer              Next-Hop                AS-Path
*>?  RD: 65535:4294967295      ESI: 00:01:02:03:04:05:06:07:08:09
     00:04:96:98:87:62    192.168.110.109         16777215    192.168.120.119   192.168.120.119    50 40 30 20 10
*>i  RD: 192.168.101.100:65535 ESI: 00:00:00:00:00:00:00:00:00:00
     00:04:96:98:87:63    0.0.0.0                 16777215    192.168.0.3       192.168.0.3        50
*>i  RD: 4294967295:65535      ESI: 00:01:02:03:04:05:06:07:08:09
     00:04:96:98:87:64    192.168.110.110         777         192.168.120.119    192.168.120.119   50 40 30 20 10
The following example displays L2VPN EVPN inclusive multicast routes:
# show bgp routes l2vpn-evpn inclusive-multicast all
     EVPN Inclusive Multicast Routes:
     Originating IP                  Tunnel ID               VNI         Peer              Next-Hop                AS-Path
*>?  RD: 65535:4294967295   Ethernet Tag: 0   Tunnel Type: 6 (Ingress Replication)
     192.168.110.109                 192.168.110.109         16777215    192.168.120.119   192.168.120.119    50 40 30 20 10
The following example shows all Type 5 routes:
# show bgp routes l2vpn-evpn ip-prefix all
Routes:
EVPN IP-Prefix Routes:
     IP Prefix/Length                           VNI          Peer                                  Next-Hop           AS-Path
  ?  RD: 1.0.0.25:48        ESI: 00:00:00:00:00:00:00:00:00:00
     125.126.127.128/32                         777          192.168.99.2                          1.0.0.25           38 25
  ?  RD: 1.0.0.25:49        ESI: 00:00:00:00:00:00:00:00:00:00
     1.0.0.0/8                                  778          192.168.99.2                          1.0.0.25           38 25
BGP Route Statistics EVPN route type 5
  Feasible Routes   : 2
  Active Routes     : 0
  Rejected Routes   : 0
  Routes from Int Peer: 0
  Routes from Ext Peer: 2
The any / netMaskLen options were added in ExtremeXOS 11.0.
Support for IPv6 was added in ExtremeXOS 12.6 BGP.
Support for Layer 3 VPNs was added in ExtremeXOS 15.3.
Support for IPv4 VXLAN was added in ExtremeXOS 22.3.
Support for L2VPN EVPN was added in ExtremeXOS 30.2.
Support for user-specified VRs was added in ExtremeXOS 30.3.
Support for EVPN auto-discovery and EVPN Ethernet Segment routes was added in ExtremeXOS 30.4.
Support for Type 5 routes (ip-prefix) was added in ExtremeXOS 30.6.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature, see the Switch Engine v33.6.1 Licensing Guide document.
