Disables LSP sharing for Layer 2 VPN pseudo-wires.
This command has no keywords or arguments.
Disabled.
This command disables LSP sharing for L2VPN PWs. When LSP sharing is disabled, only 1 named LSP is used for a PW. When LSP sharing is enabled, up to 16 named LSPs are used for a PW.
If LSP Sharing is disabled, and more than 1 Transport LSP is programmed into HW, all but 1 Transport LSP is removed from HW, and the configuration is preserved. If LSP Sharing is enabled, and more than 1 Transport LSP was previously configured, the remaining LSPs is programmed into HW as they become available for use.
The following command disables LSP sharing for L2VPN PWs:
disable l2vpn sharing
This command was first available in ExtremeXOS 15.4.
This command is available only on the platforms that support as described in the Switch Engine v33.6.1 Licensing Guide document.
