create bgp evpn instance
create bgp evpn instance evpn_instance_name
Description
Creates an EVPN instance.
Syntax Description
bgp BGP capability.
evpn EVPN protocol.
instance Specifies creating an EVPN instance
evpn_instance_name Name of the EVPN instance.
Default
N/A.
Usage Guidelines
The EVPN instance will become active if the configured VNI matches the configured VNI of a virtual network.
The following example creates an EVPN instance named "my_evpn":
# create bgp evpn instance my_evpn
This command was first available in ExtremeXOS 30.2.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature, see the Switch Engine v33.6.1 Licensing Guide document.
