show netlogin session
show netlogin session {all | summary} {mac-address mac_address} {ports ports} {agent [convergence-endpointdot1x | mac | web-based]}
Description
Use this command to display the active authenticated sessions for both policy and non-policy mode.
Syntax Description
allInclude sessions with 'terminated' status.
summaryDo not display detailed information.
mac-addressSpecify a MAC address.
mac_addressSpecify a MAC address.
portsPort or range of ports.
agentSpecify an agent type.
dot1xIEEE 802.1X Port-Based Network Access Control.
macMAC authentication.
web-basedWeb-based authentication.
convergence-endpointConvergence-endpoint authentication.
Default
N/A.
Usage Guidelines
None.
The following example shows a summary of the active authenticated sessions:
# show netlogin session summary
Port         Address type Address                  X W M C B
23           mac          00:00:88:88:00:00            X
23           mac          00:00:88:88:00:01            X   X
23           mac          00:00:88:88:00:02            X   X
23           mac          00:00:88:88:00:03            X   X
23           mac          00:00:88:88:00:04            X
X - dot1x
W - web-based
M - mac
C - convergence-endpoint
B - Blackholed in FDB
The following example shows information about the authentication sessions:
Multiple authentication session entries
Port            : 1:1         Station address   : 00:04:f2:9f:48:fe
Auth status     : success     Last attempt      : Fri Nov 17 21:56:01 2017
Agent type      : cep         Session applied   : true
Server type     : local       VLAN-Tunnel-Attr  : None
Policy index    : 2           Policy name       : NProfile_16 (active)
Session timeout : 0           Session duration  : 2 days, 21:57:19
Idle timeout    : 300         Idle time         : 0:00:00
Auth-Override   : enabled     Termination time  : Not Terminated
Dynamic Web-redirect : http://10.127.26.8:80/static/index.jsp
Port            : 15          Station address   : 00:00:00:00:0b:00
Auth status     : success     Last attempt      : Thu Jan 30 12:48:04 2020
Agent type      : mac         Session applied   : false
Policy index    : 0           Policy name       : No Policy applied
Session timeout : 0           Session duration  : 0:00:04
Idle timeout    : 0           Idle time         : 0:00:00
Auth-Override   : disabled    Termination time  : Not Terminated
The following example shows information about dynamic captive portal redirection using RADIUS VSA (lines 12-14):
Port            : 25          Station address   : 00:0a:01:00:00:02
Auth status     : success     Last attempt      : Mon Sep 22 18:17:20 2025
Agent type      : mac         Session applied   : true
Server type     : radius      VLAN-Tunnel-Attr  : None
Policy index    : 2           Policy name       : profile2 (active)
Session timeout : 40          Session duration  : 0:00:01
Idle timeout    : 50          Idle time         : 0:00:00
Dynamic Web-redirect : http://2.2.2.2:8012/
* (CIT_33.5.0.259) 5320-24P-8XE-SwitchEngine.5 # sh policy captive-portal web-redirect 00:0a:01:00:00:02
This command was first available in ExtremeXOS 16.1.
Sessions shown for both policy and non-policy mode was added in ExtremeXOS 30.7.
Sessions shown for dynamic captive portal redirection using RADIUS VSA was added in version 33.5.1.
Platform Availability
